unlock pectel T6 ecu
hi,
i have a pectel t6 ecu and i want to know who can unlock it and fit a std map just to start the car. I don't care if i loose the actual map, i changed spec and now i will map it on the rollers. Please if anyone knows something please send me contact details and names.
thanks
thanks
It needs to be a "Pectel External" ECU. If not there is no way, besides sending it to the factory to re-flash it as "external" and erase everything in it. If it's not an "external" ECU then it's a "competitor" ECU and you'll never obtain the software that talks to it. You can figure out simply by connecting it to the software you should have, it will tell you right away if it's a competitor or an external ECU. If you don't have any software, then good luck (you need the correct profile and version that matches the ECU firmware).
DixieTheKid
11
06-06-2020 11:20 AM
