Heatshield fixing
Old Jun 1, 2011 | 01:09 PM
dbanbery's Avatar
dbanbery
Default Heatshield fixing
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_2182wt_905
thinking of buying the above to help keep the heat of my engine bay down. i know im not running a turbo but i want to do it anyways as its good practice and should help in the long run. so far my 4-2-1 manifold is heat wrapped, and as a result of this ive had to remove the starter heatshield. this was the arrangement on my red one and i had no starter motor issues. i now want to heat wrap the inlet tube that goes over the top and some other bits. what would be the best way to fix this stuff? i was thinking of going the Araldite metal route but not sure how that works with heat resistance.
what do people normally do? i'd rather not rivet anything, especially since the inlet tube is plastic amongst other things.
Old Jun 1, 2011 | 04:09 PM
ChrisH's Avatar
ChrisH
Heat shield can be screwed, glued, whatever. Araldite metal glue is fine, i used evostick (although i screwed it aswell) So what are you heat wrapping your inlet with? The stuff in the above link?
Old Jun 1, 2011 | 04:29 PM
dbanbery's Avatar
dbanbery
Yeah, just the underside i was planning to do as i dont think its worth doing the entire thing
Old Jun 1, 2011 | 04:38 PM
ChrisH's Avatar
ChrisH
I would of used the exhaust heat wrap, looks nicer. But for the actual engine bay, stuff in the above link is good.
Old Jun 1, 2011 | 05:39 PM
djvu's Avatar
djvu
have you got a k&n on your car, Got told today by a tuner round my way that he was asked to put on a load of chrome gibbings on some chaps rs so he did, When the bloke got his car and went off he said it felt like it wasnt running as quick there was something missing and it turned out this heat shield he put over the turbo to keep the temps down ended up sending the heat acrosswards towards the k&n creating more a warmer induction and knocked on the rollers 10- 15 bhp off the power
Old Jun 1, 2011 | 06:00 PM
dbanbery's Avatar
dbanbery
i have. it not turbo'd though so its not as bigger issue as that, but that is a worthwhile point. i need to think about the flow of hot air and where it goes.
the plan is to remove the drivers side headlamp when i track it.
Old Jun 1, 2011 | 06:15 PM
djvu's Avatar
djvu
i wouldnt of thought it either before he said, Id assume it would apply to xr3i,s or in fact any car, If ya removing a headlamp id make up a pipe or something to blow cold on it, That exhaust wrap seemed to be good untill i saw what it did to manifolds
Old Jun 1, 2011 | 06:37 PM
ChrisH's Avatar
ChrisH
Cut a circular hole in the bumper with a pipe going up to the intake
Old Jun 1, 2011 | 06:50 PM
dbanbery's Avatar
dbanbery
hahaha there is already a standard induction pipe on the car.
i have a pair of rough bumpers that i was going to paint matt black, so i could mod those instead.
Old Jun 1, 2011 | 06:55 PM
ChrisH's Avatar
ChrisH
Thats the way to do it.
Old Jun 1, 2011 | 06:57 PM
djvu's Avatar
djvu
is there any pics off that set up , bet one on both sides dont look to bad in a oval kinda shape
Old Jun 1, 2011 | 07:07 PM
ChrisH's Avatar
ChrisH
Yeah i'm sure i've got one kicking about.
The pipe doesn't need to be as big as that as this has 292BHP Normally Aspirated ST170
Old Jun 1, 2011 | 08:34 PM
dbanbery's Avatar
dbanbery
ah right
well mine comes down the other side..... let me see if i have a pic..
this is when i first got it:
as you can see it goes to the drivers side, different to ERSTs and MFI cars. there isnt a lot of space but there is enough. there is an oval hole in the slam panel with an induction hose attached to it as standard. my plan is to heat proof the underside of the plastic induction hose thing, and possibly create some sort of shield that can split the hot/cold airflow.
Old Jun 1, 2011 | 08:40 PM
djvu's Avatar
djvu
ah right
hmm that is different
Old Jun 1, 2011 | 08:46 PM
dbanbery's Avatar
dbanbery
the induction kit is just a cone that goes on the end of the plastic thing that is pointed down. it is quite out of the way.
Old Jun 1, 2011 | 09:56 PM
ChrisH's Avatar
ChrisH
I'd be tempted to get the Rs Turbo induction tube that bolts to the rocker cover and heat wrap that with a tube that points out the front somewhere
Old Jun 2, 2011 | 08:46 AM
dbanbery's Avatar
dbanbery
what and send the inlet the other side of the engine over the gearbox? i dont know whether the bonnet would clear it tbh.
ironically it runs cooler than it did since ive put these things on - and ive removed two heat shields [starter motor - didnt fit with the 4 branch and the manifold heat shield that bolts to the cast iron manifold]
i suppose another option would be to get a different inlet hose off a zetec or similar..... there must be a reason why ford moved it though..
Old Jun 2, 2011 | 10:24 AM
ChrisH's Avatar
ChrisH
Yeah thats what i meant. Hmm, i've never seen one like that before. As you say there must be. Is the intake to the side of the rad? If i remember correctly on the other versions it sits on top of the rad which could be heating the air, just a thought.
Old Jun 2, 2011 | 12:00 PM
dbanbery's Avatar
dbanbery
this is the standard setup for all EFI mk4s . the intake sits at the side of the rad yeah.
thats my first one
this is the one that got nicked when i was doing work on it:
if you see that big rad hose at the bottom that comes off the water pump, the intake goes through the front of the car there.
Old Jun 2, 2011 | 12:21 PM
ChrisH's Avatar
ChrisH
Oh right, for some reason i remember my old XR2i having the intake on the other side?
Old Jun 2, 2011 | 12:31 PM
dbanbery's Avatar
dbanbery
Old Jun 2, 2011 | 12:35 PM
markc's Avatar
markc
if you want it down the other side use a mk5 escort efi cvh cross over pipe and put your cone on top of the gear box. the frst cross over will fit under the bonnet as well as its practially the same engine
ChrisH's Avatar
ChrisH
Well, i don't remember that lol, been a few years since i looked under the bay of a 1600 CVH if i'm honest.
Old Jun 2, 2011 | 12:37 PM
dbanbery's Avatar
dbanbery
its ok it gets complicated when you look at akll the variables. the zetec fiesta has the intake on the other side
Old Jun 2, 2011 | 12:59 PM
ChrisH's Avatar
ChrisH
Maybe you could do something with the indicator hole?
Old Jun 2, 2011 | 01:03 PM
dbanbery's Avatar
dbanbery
its not much of a hole unfortunately, i would have to put a hole through the inner wing. tbh ill more than likely hole saw a port in my spare bumper and then sort out an induction pipe. That with some heat proofing and shielding should be enough.
this is just fiddling really -
Old Jun 2, 2011 | 01:14 PM
ChrisH's Avatar
ChrisH
Sounds like a plan, it's probably one of the coldest air feeds too.
Old Jun 2, 2011 | 04:56 PM
dbanbery's Avatar
dbanbery
well if i end up putting throttle bodies on it the airflow will come from the heater box louvres anyways later on
Old Jun 2, 2011 | 05:31 PM
ChrisH's Avatar
ChrisH
Good plan!
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
Cos500
Sep 16, 2015 09:50 PM
landaqmabba
Sep 15, 2015 07:16 PM
