hi series 1 problems
Old May 25, 2011 | 08:11 PM
hbjseries1's Avatar
hbjseries1
Default hi series 1 problems
hi im harry, im 17 and im having trouble with my seires 1 i purchased 2 days ago.
i put the key in and theres nothing. no lights on the dash no crank nothing.
ive cleaned the earths and put them back but still nothing any ideas
thanks
Old May 26, 2011 | 12:49 PM
hbjseries1's Avatar
hbjseries1
btw ive tried the battery?
Old May 26, 2011 | 12:59 PM
stevo123's Avatar
stevo123
Sound like you may have old immobilizer somewhere cutting power or perhaps the ignition barrel is faulty. As well as checking the earth also check the positive from the battery to the starter and then from starter to the alternator. I once saw a W reg xr3 with a weird no power problem and it turned out the battery + lead has a fuseable link inline with the cable that had blown. You can get a cheap multimeter for around a fiver and I am sure it will pay for itself in no time.
Remove steering column shroud and check for burnt out wiring 1st - seen this before and its an easy/quick thing to try first.
Good luck - post up how you get on
Old May 26, 2011 | 04:08 PM
hbjseries1's Avatar
hbjseries1
thanks il give it a shot now
Old May 26, 2011 | 05:07 PM
hbjseries1's Avatar
hbjseries1
this is it, is that 1 ment to be empty? the 1 on the right
and im gonna check the other bit with the starter and alternator 2moz if the weather improoves.
Old Jun 4, 2011 | 01:06 AM
hbjseries1's Avatar
hbjseries1
hi i have a update, i was told their is no immobilizer from the previous owners and wen i put the terminals on the batterys nuffin happens still but i used 2 cables goin from the positive and negative to the empty slot in the key hole shown in the pic above and and the other wire to where the black and yellow wire bellow it and the engine started ticking over,
and also when i touch the cable on the empty slot above and wiv the black cable on the left the dash lights come on any ideas?
Becka674
11
Oct 8, 2015 03:11 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Bransby
Sep 11, 2015 01:09 AM
