Ford ka duratec engine
Old May 22, 2011 | 05:05 PM
megray's Avatar
megray
Default Ford ka duratec engine
Hi all. Last week my water expansion bottle burst, replaced it with a new one. Since then, my temp warning light comes on now and again, as soon as I put my heater on full blast, it goes off. It helps if I keep my heater on a little, but then I get to hot in the car. Have I got an airlock do you think ? If so how do I clear it. I am not to technical with cars. Any help at all please.It is a 2003 ford ka with the 1.3 duratec engine. Many Thanks.
Old May 22, 2011 | 05:59 PM
Churtz's Avatar
Churtz
Hi, Suspect an airlock. They can b a real pain to bleed someimes.
Matt
Old May 22, 2011 | 06:07 PM
megray's Avatar
megray
Matt
Thanks Matt for Help, So is it a garage job, and what cost do you think, Thanks Again.
Old May 22, 2011 | 06:14 PM
mk3cosproject's Avatar
mk3cosproject
ford crazie
Default thermostat
i had a thermostat problem with mine and apparent its common theyre cheap incase your worryed
Old May 22, 2011 | 06:29 PM
megray's Avatar
megray
o.k. many thanks for help.
Old May 22, 2011 | 06:30 PM
Danster76's Avatar
Danster76
I would be looking at the thermostat too.
Old May 22, 2011 | 06:48 PM
megray's Avatar
megray
Many Thanks, can I run it if I just remove the stat to see if that cures it?
Old May 22, 2011 | 07:07 PM
mk3cosproject
ford crazie
yep you can i did for about a week on short runs of bou two miles to work but it isnt advised other than that your heater wont work because itll keep circulating the water and wont get up to temp very fast.
if you get into bother try the kaklub forum for a run through on how to fix it the guys there are welcoming and will help as much as they can with any more problems
http://www.kaklub.co.uk/
Old May 23, 2011 | 06:55 AM
Hobomassiv's Avatar
Hobomassiv
Hi,
If you are lucky an independant local garage with some spare time might help you bleed the system quickly for a tenner or something.
It might very well be the thermostat though, they are quite cheap to replace and quite easy to do, the duratec Ka Haynes manual is very useful.
As well as the Kaklub there is fk-oc.com which is free and busy
Old May 23, 2011 | 08:56 PM
megray's Avatar
megray
Many thanks to all for your help. I got the R.A.C out to it, he removed the stat, I dangled it on a piece of string in boiling water. and it did not open..is it faulty?? getting a new one fitted tomorrow.
Old May 24, 2011 | 06:46 PM
mk3cosproject
ford crazie
ya boiling water should have opened it. you need a new stat
Old May 24, 2011 | 06:54 PM
megray's Avatar
megray
Many thanks to all of you for the advice and replies. New stat now fitted.(£18.00) robbers, and all is well. Thanks again guys. Great site.
Bailes1992
Aug 16, 2015 07:14 PM
