just a efi quiestion
Old May 24, 2011 | 07:02 PM
chigwellboy's Avatar
chigwellboy
Default just a efi quiestion
hi looking to buy a xr3i cab efi do i need to change the loom to put a fiesta turbo engine in it
Old May 24, 2011 | 07:06 PM
phil_rs's Avatar
phil_rs
yam yammer
Great news, you don't! Apparently there are a couple of pins which need swapping where they fit into the Fiesta ECU and it runs fine
Old May 24, 2011 | 08:02 PM
JonathanJ's Avatar
JonathanJ
As long as you use the OFAC management then it is an easy swap , all you need is the ecu and map sensor and then swap a couple of wires and it is done , if you go OFAB it can be a bit worse but can still be done
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
