Cossie oil change
Old May 20, 2011 | 02:19 PM
burnhamshaun's Avatar
burnhamshaun
Default Cossie oil change
Gonna give the saph an oil change tonight 1st time I've ever done 1 any do's donts I also have an oil cooler so what's the score with draining this and does it need to be primed also does it matter weather oil is hot or cold plus am I right in thinking filter has to be primed and how many liters should I be looking at putting in not including oil cooler
Old May 20, 2011 | 02:53 PM
COCHYN's Avatar
COCHYN
Don't strip the thread on the sump plug thread
Old May 20, 2011 | 03:23 PM
martysmartie's Avatar
martysmartie
Nothing special, as with any engine the oil should be hot as the oil is thinner and thus will drain easier, also once draining remove the filler cap as well, if you haven't already make sure you have the right filter as they are different between 2WD and 4x4.
Never prime mine, just refill and start up, you could always pull the king lead etc if wanting to turn over first to get the new oil circulating but I don't see the point personally!
Oil capacity is 3.5 litres from memory, can't remember if that is excluding or including filter!
Martin
Old May 20, 2011 | 06:45 PM
burnhamshaun
Ok doin it now cheers
Old May 20, 2011 | 07:04 PM
RS500/364's Avatar
RS500/364
i used to leave mine to drain overnight
just keep the sump plug with the keys!
Old May 20, 2011 | 08:21 PM
burnhamshaun
All done and started fitting new skirt clips my god it makes a difference the skirts are solid now 3 fitted only another god knows how many to go then to fit the new diff mount
Bailes1992
Sep 3, 2015 02:17 PM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
track.focus'd
Aug 12, 2015 05:53 PM
