Saph roof lining
Old May 20, 2011 | 12:23 PM
burnhamshaun's Avatar
burnhamshaun
Default Saph roof lining
Gonna get mine done been quoted £220 supplided and fitted good price or not this also includes the piller triangles too
Old May 20, 2011 | 12:55 PM
Phil2002's Avatar
Phil2002
do it your self mate the hardest part is getting it out. make sure you use high temp glue tho.
Old May 20, 2011 | 02:09 PM
burnhamshaun
Tbh be honest I'd be worried about doing a crappy job lol prob better paying for it to be done and think someone on here said it comes out of the door or boot is that correct
Old May 20, 2011 | 08:45 PM
Phil2002's Avatar
Phil2002
i got mine out the passenger front door recline the seats right back.
If you get the right glue nice sharp stanley blade and a clean dry sponge it's easy.
1) remover roof lining
2) rip of old cloth
3) remove any loose old sponge (i brushed all mine off with a stiff coconut hair broom)
4) spray roof lining with high temp glue and leave for about 30 seconds
5) gently lay your new cloth onto the roof lining
6) press the new cloth down with the dry sponge this stops it getting finger inprints in the cloth.
7) once the cloth has been worked into all the corners etc trim it leaving about 50mm excess to fold round the back
8) re fit it the habdles sunvisors will help hold it all in place too.
about an hour and half tops.
But to answere your question i think 220 is a bit steep.
If you don't want to do it your self i would get autoflock(trader on here) to flock it, it will never sag again. If mine sags again i'm gonna get mine flocked.
do search on here about flocking it there was a thread a few weeks ago about it.
Old May 20, 2011 | 08:47 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Was quoted 100 to do mine from a good local trimmers
Steve
Old May 20, 2011 | 08:49 PM
Phil2002's Avatar
Phil2002
here you go fella!
https://passionford.com/forum/genera...eadlining.html
Old May 20, 2011 | 09:04 PM
burnhamshaun
Nice one just had a read thru that not sure about getting it flocked tbh as I don't think the finish would be as nice as a tight cloth finish but the thing that puts me of about doing it myself is trying to remove the fecking thing then there's the what if I break something
Old May 21, 2011 | 09:58 AM
1223456's Avatar
1223456
There are pro's and cons to both methods, ultimatly flocking would give the best finish, but the prices above seem very very reasonable, you need to make sure the adhesives being used are correct in terms of durability and temp. I alot of adhesives loose their properties when subjected to a bit of heat, although they regain them once cooled down it is too late when they have delaminated from the roof.
If you do try yourself, test the glue on another object and see what the viscosity is like of it, if its too thin let it flash off a bit till its more of a tack consistency, this will remove the risk of print through, believe me its so easy to bugger up a job right at the last minute, you could lay down the majority of the roof then right at the end the glue could be a tad too wet and print through the fabric. And I can tell you the colourfull language generated from such an incident is shocking!!
Old May 21, 2011 | 10:53 PM
burnhamshaun
Is the sun roof cover flocked as standard by any chance
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
