turbo repaire kits
Old Feb 8, 2005 | 07:36 PM
skiddley bop 4 pot's Avatar
skiddley bop 4 pot
Default turbo repaire kits
does anyone know how difficult it is to survice your turbo with a service kits ie new seals new bearings
Old Feb 8, 2005 | 09:22 PM
b13nde's Avatar
b13nde
you carnt you need speclist tools get hold of universal turbos they done mine top job cheap and i quick turn around time bell them on 01425471421
Old Feb 8, 2005 | 09:31 PM
skiddley bop 4 pot
cheers mate
Old Feb 8, 2005 | 11:36 PM
richm's Avatar
richm
yes you can... Stu @MSD on here sells the kits, but really you need to get the core balanced properly afterwards.
Old Feb 11, 2005 | 01:56 PM
wilky's Avatar
wilky
Default 620 ti sherpa
if you use the old compresser nut an mark turbine shart
to compresser wheel to the nut you can do it your self
i have done it a few time's
Old Feb 11, 2005 | 10:26 PM
markk's Avatar
markk
its actually very easy to fully service you turbo , ive done prob 10 , all kits from MSD, the biggest arse ache is trying to remove seized studs from the housings , you WILL need to heat most of them up !, fitting the kit is very easy, specially as all garret parts are individually balanced
just to put your mind at rest , i built one a while back that eat the thrust in about 50miles i thought WTF , so i took it to a local turbo geezer who checked the balance and it was fine WELL within spec , was something other than the kit that had failed. so new kit and has been fine since !
Old Feb 13, 2005 | 10:56 PM
skiddley bop 4 pot
Default turbo kits
cheers for info mate very helpful
Matt Baxter
Sep 16, 2015 08:30 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
