ford sierra computer
Old May 4, 2011 | 08:15 PM
bulbashar's Avatar
bulbashar
Default ford sierra computer
does anyone know if ford trip computer can be installed at o ford sierra 1.6 cvh?
Old May 5, 2011 | 06:39 PM
Yes of course, ford did it, just a case of how much you need to add to your car to make it work, and cost of parts, depends what features the trip compy has, there were several fitted to sierras.
Old May 5, 2011 | 07:02 PM
bulbashar's Avatar
bulbashar
http://cgi.ebay.co.uk/SIERRA-GHIA-LA...f#ht_871wt_905
i want to install one like this.....i dont want to work many functons only the consumtion and the range!
Old May 6, 2011 | 08:01 AM
The one pictured is NOT the type that shows the fuel consumption and range etc.
The type you want is different, the one in the piccie from memory is from a xr4i, the door ajar bit/lights out warning is the same on cossie and xr4i.
To use a fuel computer one you will need a fuel flow metre on your car, as well as some electronic means of measuring wheel rotation for distance, if not it will simply work on averages, which is how I expect the ford one works, they're not especially accurate anyway.
At the very least you will need in addition to the fuel compy the fuel flow metre/device that ford used on this, it won't rely on a fuel gauge reading for this as way too inaccurate.
Old May 6, 2011 | 01:16 PM
martysmartie's Avatar
martysmartie
I remember on the MK1 Ghia it's quite a complex setup, IIRC it uses a vacuum feed and a special speedo cable or something off the drive gear amongst other stuff, I can for you if you like to see what the various components are?
Martin
Old May 6, 2011 | 02:36 PM
dojj's Avatar
dojj
Resident Wrestling Legend
assuming you are talking about the trip computer
you will only be able to fit them to the dohc engine or the 2.9 engines as they are specific to those cars
they use an injector opening (4 for the dohc 6 for the V6 which is why you can't swap them around) timing system to figure out how much fuel you have used and the speed sensor to work out how far you have travelled
you can't fit one to the 1.6 as it's got no injectors
Old May 6, 2011 | 04:57 PM
Don't know about the sierras but I have seen on other fords a fuel flow unit used for the fuel compys, but if not calibrated for this it's as you say a no no really.
Old May 6, 2011 | 05:10 PM
dojj's Avatar
dojj
The very early sierras and mk2 granadas had this set up but finding a working u it is nigh on I possible now
3doorcozmess
Aug 31, 2015 05:15 PM
tomiii
12
Aug 18, 2015 08:40 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
pegaz
Aug 12, 2015 07:30 AM
Aug 9, 2015 07:03 PM
