need help with my car
Old Apr 30, 2011 | 09:13 PM
johnny gti's Avatar
johnny gti
Default need help with my car
hi every one i got my self a mk5 escort 5 door gti, with a 2.1 turbo. but the car is not runnin good need to know wot i need to buy to make it run fast , as people say i need a remapable ecu. here is a list of wot has been done to my engine so far
2.0 zetec bottom end bored out to 2,1
2.1 forged pistons standerd conrods
1.8 16v zteck head with standerd cams
efi inlet manifold take of a 1.6 16v
2.0 mondeo injectors
2.0 mondeo aif flow mass meter with k and n filter
escort rst manifold
a garret hybird t4 turbo with twin blade a 360 trust bearin
a custom 3inch diamiter stright throw pipe
a large front mounted intercooler with dump valve
runin a staned gti gear box with standerd clutch
ans im runin the standerd gti ecu
a fuel pump of a 3.0
im now in need of know wot parts i need to make my car run some bhp as i went down the 1/4 mile last week and the best the car did was 16.0 . the car seems to not hold power in 3rd only goes to 4500rpms 1st ans 2nd redlines but all ways feels like its holdin back , any help would be much appricted thanks johnny
Old May 6, 2011 | 01:06 PM
johnny gti's Avatar
johnny gti
does any know any thing about 2.1 zetec turbos?
Old May 6, 2011 | 01:10 PM
RS 5tu's Avatar
RS 5tu
for a start you injectors will be too small and the GTI ecu no good for turbo a application thats why its running bad sort them and it should be ok,
Megasquirt is pretty cheap or ask your local tuner what they would recommend as many dont touch MS
Old May 6, 2011 | 01:11 PM
chaffe's Avatar
chaffe
Turbocharging Technician
engine size is irelevent, its a zetec so all zetec rules apply beit 1800, 2000, or 2100cc. The spec you list is all over the place, wrong management, wrong injectors, wrong turbo, it sounds like a bit of a bitza. What gearbox and clutch are you running? that is the most important thing before cosidering more power, also what fuel pump does it have?
A management change and bigger injectors are definatly on the cards as i would say you will not be making any more than 150bhp on those injectors
Old May 6, 2011 | 01:17 PM
vinnyvangough's Avatar
vinnyvangough
Pretty much as the others have said.
Who ever built it has just chucked it together and not researched anything.
Old May 6, 2011 | 01:19 PM
RS 5tu's Avatar
RS 5tu
agree with chaffe.
Also if i were you i wouldnt drive it until the bits were sorted by the sounds of it you are lucky its still going your ecu wont have a clue and its defiantly gonna run lean so there is a chance you could melt your pistons or do serious damage to something.
Old May 6, 2011 | 01:23 PM
chaffe's Avatar
chaffe
Originally Posted by RS 5tu
agree with chaffe.
when i did my mk5 xr3i 130 (turbo conversion) i ran it on std management for a few days after i had put on the various turbo bits (to prove all was well mechanically befoe putting on MS) Although all atempts were made to drive like a nun on a moped, i did put my foot down a couple of times, it felt VERY flat, and leaned off big style on the AFR gauge, not a good solution to the management required for turbo application, i think the std maff maxes out around 150bhp too.
Old May 12, 2011 | 10:02 AM
johnny gti's Avatar
johnny gti
thanks for the help so far! i have just got some cosworth injectors , but still need to know wot ecu to get as i dont know much about ecu, and wot gearbox and clutch would you reccomend?
Old May 12, 2011 | 10:44 AM
vinnyvangough
If i were you i would go and speak to a proffesional tuner as your more than likely gonna have to have a custom management system, as a standard ECU will not be of any use to you what so ever.
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
