focus door lock +starting
Old Apr 24, 2011 | 09:37 AM
cabriolet's Avatar
cabriolet
Default focus door lock +starting
having problems with a mk1 1600 focus .the door locks are intermittent .when they play up the car will not start , am assuming this is all connected had it all to bits last night the drivers lock is playing up so i found out am i on the right track, and are the door locks coded? or the same 2 door four door etc the young lady owner is losing patience help guys
Old Apr 24, 2011 | 10:22 AM
RichieST's Avatar
RichieST
Has she tried a spare key? Sounds like it could be the key at fault. When it doesn't start, what does the red light above the clock do? It should light up solid for a couple of seconds then go out, if it flashes quickly then that suggests an immobiliser problem.
Old Apr 24, 2011 | 04:53 PM
cabriolet's Avatar
cabriolet
not the key we know that for certain have scanned the car
Old Apr 24, 2011 | 08:02 PM
martysmartie's Avatar
martysmartie
I don't think the door locks are anything special, I assume when you say not working you have tried to unlock manually as well, or is that what you are trying?
Re the starting I strongly suspect this to be immobiliser related, which can be checked by doing the above.
Martin
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
PaulinhoT
Oct 28, 2015 06:06 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
tankybaby66
Aug 9, 2015 07:13 AM
