St 170
Old Apr 16, 2011 | 01:31 PM
Jam988's Avatar
Jam988
Default St 170
When I fill up the water in my car I fill it up to the max and maybe a day or so it goes down quickly but when I am stationary there is no signs of leaks why is it drinking much coolent wot can I do to find out if I have a leak on my St 170
Old Apr 16, 2011 | 02:15 PM
rubinsbin's Avatar
rubinsbin
If it was an astra-( coolant smelling of fuel/fumes)it would point to the cylinder head-but st170!-??
Old Apr 16, 2011 | 06:27 PM
Sp3no's Avatar
Sp3no
Thermostate housing leaking, it only does it when the engine is running, hence why you cant see a leak, you should see water staining on the gearbox though as an indicator. The thermostate will either require a new bung with o ring or will be cracked and will require replacment, Looking at around £200 from ford for a new one
JoeyBoyden
Jan 4, 2024 02:36 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
RsS2daz
Aug 14, 2015 05:26 AM
Bezzy41
Aug 3, 2015 10:31 AM
