No oil knocking
Old Apr 7, 2011 | 08:40 PM
neilb1's Avatar
neilb1
Default No oil knocking
Just wondering if it is the crank knocking after the st 3was run on no oil for a time, as soon as he heard it knock he put oil in but the damage was done,
Would it of damaged anything else the car runs and sound sweet apart from the knocking lol
Old Apr 7, 2011 | 08:44 PM
leemckay's Avatar
leemckay
possibly mate, if the cranks knocking its obliviously done shells in which would have put filings in the oil which would have been pumped round the engine
Old Apr 7, 2011 | 08:46 PM
neilb1's Avatar
neilb1
and i guess the shells can be done with just the crank out
Old Apr 7, 2011 | 08:52 PM
leemckay's Avatar
leemckay
yea could do if your wanting to leave the engine in the vehicle
phil_focus's Avatar
phil_focus
could be very lucky and just need new shells or could have fucked the crank. either way its a gear box off/engine out and crank removal job. you won't know the exact damage until inspected.
really don't get why some people don't check their oil regularly, take all of 1 min to lift bonnet and check the fluids and could have saved a VERY expensive repair!
Old Apr 7, 2011 | 09:16 PM
neilb1's Avatar
neilb1
I HAVE BEEN GIVEN THE ENGINE so might as well do the crank and sell it for Ł1000 lol with gearbox
Old Apr 7, 2011 | 09:29 PM
phil_focus's Avatar
phil_focus
awsome, can have a play with it now
if the crank is scored it will need either a new one or a regrind.
when you put it back together dry build it first with plastigage to check all the bearing clearances
Old Apr 7, 2011 | 09:34 PM
Alvyn's Avatar
Alvyn
may have damaged the rods along with the ends!
Old Apr 8, 2011 | 03:05 PM
As said could well have spun some shells in the big ends, if it is knocking it won't be just the shells, the crank will need attention.
tankybaby66
Feb 6, 2016 02:24 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
