RST GEARBOX
Old Feb 4, 2005 | 04:54 PM
Speedy Gonzalez's Avatar
Speedy Gonzalez
Default RST GEARBOX
Hi all, i've got a busted RST box i also have an escort diesel box which i want 2 put in' is it possible 2 put the LSD out of the knackered box into the diesel box if so how do i do it? any help will be much appreciated as i need 2 get back on the road!!!!
Old Feb 5, 2005 | 08:45 AM
JesseT's Avatar
JesseT
This has been asked a billions of times, but yes, it can be swapped. As the RST (S2) box is knackered, I take it that the mainshaft is history. This means that you have to use the diesel mainshaft and thus the crown wheel too. Now, the diesel crown wheel can be either with 6 or 8 bolt pattern, where as the S2 has always 8 and the S1 has always 6. This means that propably you need to redrill and tap the crown wheel for the correct pattern. I've done this with mine, but I warn you, the crown wheel is not made of the softest of materials.
mjonathan24
Oct 29, 2015 10:39 PM
A.t.p
Oct 23, 2015 07:54 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
