Year 2000 Focus - Noise and Vibration when turning left
Old Mar 5, 2011 | 03:22 PM
laserbream's Avatar
laserbream
Default Year 2000 Focus - Noise and Vibration when turning left
My Focus is making a grinding/rubbing noise but only when turning left. Any degree of lefthand turn will trigger the problem, which is audible and felt through the passenger side floor and steering wheel. It seems to be coming from the passenger side.
I've had the front nearside wheel bearing replaced with no effect. I crawled under there yesterday and the only suspicious thing was a ridge of grease on the surfaces surrounding the inner CV joint, as if grease had been flung out from a rotating surface. I loosened one end of the boot and pumped some CV grease in but there has been no change or further buildup of grease.
I've had the car suspended above the ground with the engine running and the problem does not occur. There is also no play or give when the tyre is off the ground and manipulated.
I'm stumped - can anyone help?
Old Mar 6, 2011 | 08:14 PM
martysmartie's Avatar
martysmartie
Assuming the brakes are known to be ok as this would cause this if the discs have warped etc I would look at the ARB and the drop links as these are known to cause the problems you describe with these.
Martin
Old Mar 8, 2011 | 07:24 AM
Mollymanta.'s Avatar
Mollymanta.
sounds to me like the cv joint is away
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
The Underdog
29
Sep 7, 2015 09:49 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
tankybaby66
Aug 9, 2015 07:13 AM
