temp gauge
Old Mar 31, 2004 | 05:46 AM
ricky's Avatar
ricky
Default temp gauge
how to test the teppeture gage
engine running until fans cut in new temp switch
but the gauge dont move any idea
Old Mar 31, 2004 | 09:19 PM
richm's Avatar
richm
if you take the wire off the sender and touch it to vehicle chassis with ignition switched on, the gauge should go up to max. If so, then the sender is faulty.
If it doesn't move, then either the gauge or wiring is faulty.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
