What does these relays do ?
Old Feb 17, 2011 | 09:09 PM
sirloveyou's Avatar
sirloveyou
Default What does these relays do ?
I have a mark 4 fiesta with no spark !
The ecu has been tested new coil pack and crank sensor
I have been digging around looking for other causes ! in the main fuse box under the bonnet i found 2 relays missing with bits of wire in them bridging across ! lol some how i dont think ford used this method
its the green relay top left and then there is a row of orange ones and the end right
do eitheir of these have anything to do with the ignition ? maybe imobilser ? or something spart related ? I cant think of anything else that may be causing it !
Cheers Daniel
Old Feb 19, 2011 | 03:16 PM
Do you not have a a handbook, as that lists them, if not buy a haynes manual as that will hopefully list them, or find someone with a mark4 who will let you have a look at the handbook and photocopy the relay positions if listed.
It defo isn't right, if one is the pcm(as I think ford called it at the time) relay this would stop power to the ecu and hence coil/spark, it would also stop fuelling.
Old Feb 24, 2011 | 11:32 AM
rob115's Avatar
rob115
ive got what you need in pdf but cant attach it on here send me your email and i will send it to you
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
