help identifying the engine and ecu
Old Jan 30, 2011 | 06:36 PM
mill5y's Avatar
mill5y
Default help identifying the engine and ecu
Bought myself a mondeo 2.0 blacktop
First question first, is this the right type??
Second question
After looking at the loom and what needs moving for a non pats ecu, it's a 104 pin
the haynes manual says injectors at pins 51, 52, 39, 35.....
Actual is non of the above non of the colours wrote down match the actual in front of me. pin 35 is empty!
Can anyone help identify what engine it is and what ecu/ wiring work is required for fitment into a mk4 escort....
If it helps, pins 1-12 are empty.
The earth from ecu is pin 25
Old Jan 30, 2011 | 07:57 PM
mill5y's Avatar
mill5y
The engine number is unreadable due to surface corrosion the head has the number xs7g-6090-ab
The air filter has a sticker saying zetec-e
If anyone has wiring diagrams saved could you post or send them so I can compare with my engine just trying to find out whats what
cheers
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
3drRich
Sep 13, 2015 07:32 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
