transit wont start??? but will start on easy start??
Old Jan 27, 2011 | 08:12 AM
slysi's Avatar
slysi
Default transit wont start??? but will start on easy start??
hi, i have a 2001 2.0 turbo diesel transit, it willnt start on its own! give it a bit of easy start and it will start and run but will be very flat???? leave it half hour and it willnt start unless you give it some more easy start???? help!!!!!
Old Jan 27, 2011 | 09:19 AM
Turbosimpsons's Avatar
Turbosimpsons
heater plugs. or the engine is goosed
Old Jan 27, 2011 | 07:10 PM
Lack of(suffecient) fuel, try the obvious first, bleeding and fuel filter.
Old Jan 27, 2011 | 07:17 PM
LukeDaisley's Avatar
LukeDaisley
dont quote me but i think there is a one way valve after the filter to stop fuel draining back to the tank, these are shit. you could try taking it out and replacing it with a hand primer.
Old Jan 28, 2011 | 09:04 AM
bangerboy33's Avatar
bangerboy33
It will probably b addicted now had same problem turned out to b diesel pump replaced that with a expensive new one had it all done by Ford but it still wouldn't start without a sniff bloody stuff worse thing invented.
Old Jan 28, 2011 | 09:30 AM
kev 3dr's Avatar
kev 3dr
having same problems with a 2.4 one and ive had pump recond too and tried running it off a seperate fuel system and will only run for 15 minutes or so then wont re start til it feels like
Old Jan 28, 2011 | 09:31 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Originally Posted by bangerboy33
It will probably b addicted now.
Please eloborate...
Old Jan 28, 2011 | 09:42 AM
bangerboy33
I don't know how to explain it other than the engine gets addicted to easy start some how like a junkie needs a fix its the same if u use brake and clutch cleaner I heard it something to do with the ethanol content in it?
Old Jan 28, 2011 | 09:50 AM
chaffe's Avatar
chaffe
Oh i see, is there a cure? some sort of methadone programe prehaps?
Old Jan 28, 2011 | 10:07 AM
bangerboy33
Well yeah its very similar just stop using it and keep cranking for a few minutes everyday without using it and it will fire after a few days took me 6 days of this morning and night b4 it would fire without it lol!
Old Jan 29, 2011 | 10:22 AM
Alvyn's Avatar
Alvyn
yes the vehical will have to have the ORIGINAL problem fixed lol
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Fordmad!
Sep 26, 2015 05:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Adam-M
Aug 27, 2015 08:55 AM
SteveyDee
Aug 25, 2015 07:48 PM
