ford fester engine swap
Old Jan 25, 2011 | 07:43 PM
bangerboy33's Avatar
bangerboy33
Default ford fester engine swap
I know its a bit old hat but i have a mk2 fester ohv and am going to put a cvh from a mk3 escort in it do i have to change any engine mounts. i dont really want to cause i am on the rock & roll and money is well tight any suggestions would b helpful thanks
Old Jan 25, 2011 | 07:49 PM
martysmartie's Avatar
martysmartie
Yes I should think the mounts are different, although other Fiestas were CVH but not sure what was different.
Martin
Old Jan 26, 2011 | 12:53 AM
fogulbennett's Avatar
fogulbennett
We had too change the cradle and rubber mounts for the gearbox had too use the ohv cradle on the cvh.
Fogul
Old Jan 26, 2011 | 12:59 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Old Jan 26, 2011 | 01:52 PM
mikey200615's Avatar
mikey200615
the engine mount slightly different also but you can still make it fit if your using the 5speed box aswell like fogul says need to change the cradle and mounts from 4speed onto 5speed and change the linkages also the 5speed linkage is longer
Old Jan 28, 2011 | 08:56 AM
bangerboy33
No using 4speed was thinking of using the cradle mounts of the ohv gearbox? Wondering about the wing mount though?
JoeyBoyden
Jan 4, 2024 02:36 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
