cosworth engine loom
Old Jan 22, 2011 | 08:08 AM
wayne dowling's Avatar
wayne dowling
Default cosworth engine loom
Hi just a quick question are the ECU plugs the same on a p8 as the l6
thanks wayne
Old Jan 22, 2011 | 10:02 AM
oldford's Avatar
oldford
When you mean the connector at the end of the wiring loom with "plug", then Yes, but P8 has more wires normally (Knock sensor, Oxygen sensor).
Also the P8 uses a different TPS-sensor with a different connection.
Old Jan 22, 2011 | 10:11 AM
wes's Avatar
wes
Yes L1 / L6 / L8 / P8 all use the same 35-pin connector plug.
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
