Valve adjustment problem! PLEASE HELP!!!
Old Jan 3, 2011 | 06:05 PM
Flathead45's Avatar
Flathead45
Default Valve adjustment problem! PLEASE HELP!!!
Hi, i have been working on my mates 1.3 fiesta mk5 for a while now, but the valves keep going out of adjustment!!!? Now its too the point there is no more adjustment left in the rockers and there is still alot of slack with the push rods :S any ideas? Could it be the lifters? Please help!!
Thanks
Frazer
Old Jan 3, 2011 | 06:32 PM
Taps's Avatar
Taps
New camshaft and followers will cure your problem.
Old Jan 4, 2011 | 02:28 PM
Flathead45's Avatar
Flathead45
Why would they fail? The engine has only done 35k :S
Old Jan 4, 2011 | 02:40 PM
phil_focus's Avatar
phil_focus
poorly maintained would be my bet. possible blockage stopping proper cam lubricaton maybe
Old Jan 4, 2011 | 04:06 PM
Taps's Avatar
Taps
Yep, plus they went through a stage of eating camshafts due to poor quality, 35K means nothing
Old Jan 4, 2011 | 09:06 PM
Flathead45's Avatar
Flathead45
Hmmm, i did notice that the oil looked like it had never been changed since it was filled at the factory, any ideas where i could get a camshaft and lifters from for a good price?
Old Jan 4, 2011 | 09:09 PM
TMC225Y's Avatar
TMC225Y
Rocker shaft and bushes probably well shagged too. One of these engines with worn valvetrain will rattle like mad, no matter how you set the valve clearances. They seem to keep going though... Normal thing is town driving, lack of oil changes, feed to rocker shaft gets blocked, then wears everything out, even with low milages.
Old Jan 4, 2011 | 10:20 PM
Flathead45's Avatar
Flathead45
Ive recently fitted a new rocker set, anywhere i can get a camshaft and followers for a good price? And do i need to remove the engine to replace them?
Old Jan 4, 2011 | 10:56 PM
cossyking's Avatar
cossyking
yes you do engine needs to go upside down to get followers in
Old Jan 4, 2011 | 11:12 PM
dug112y's Avatar
dug112y
passionford pro
be easier just buying an engine and swapping them...the engines i mean not the cam etc
Old Jan 4, 2011 | 11:42 PM
Flathead45's Avatar
Flathead45
Yeah i thought that lol
Old Jan 5, 2011 | 04:49 PM
TMC225Y's Avatar
TMC225Y
....and if the lubrication problem, if there is one, is not sorted, the new lot will wear out in no time too. Before you take off the old stuff, I would make sure you have oil coming out between the rockers and shaft with the engine idling and rocker cover off.. Give the engine a couple of flushes and get the oil fairly clean before throwing new bits at it. God I hate these engines...! Most of them were knackered by short journeys and lack of oil changes. They tend to blow quite a lot of carbon past the rings which shits the oil up and needs getting rid of regularly... which it normally isn't!
Old Jan 5, 2011 | 05:08 PM
Flathead45's Avatar
Flathead45
Would i be better to just fit a zetec 1.25 into it?
Old Jan 5, 2011 | 05:10 PM
dug112y's Avatar
dug112y
passionford pro
read up i said replace the engine .
flathead.. no just replace it with whats there mate
Old Jan 5, 2011 | 05:38 PM
TMC225Y's Avatar
TMC225Y
"replace the engine",- finding an HCS engine without knackered valvegear practically impossible i would think. This ones's done 35K and is worn out, don't say much for them really.... Could fit a louder stereo perhaps?
Old Jan 5, 2011 | 05:50 PM
dug112y's Avatar
dug112y
passionford pro
this is true lol
yatta
May 21, 2016 10:31 PM
15
Oct 7, 2015 03:43 PM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
cossirob
Sep 3, 2015 09:17 PM
