s1 battery
Old Jan 3, 2011 | 01:40 PM
cozzy lee's Avatar
cozzy lee
Default s1 battery
does anybody know where i can get a battery for a s1 turbo,tried local motorfactors,halfords etc,they all seem to be round terminal type,im after the square type,any sites reccomended,dont really want to change the leads to round,as the car is standard and all original,its been 4yrs since last battery change,it was difficult back then to get one,so any help would be greatly appreciated.......cheers
Old Jan 3, 2011 | 02:17 PM
iansoutham's Avatar
iansoutham
OCD Victim
You would be better off converting to round-post as I think there is only Yuasa left who do the square-post, and that is just old stock.
By mid-2011, there will be no-one able to supply square-post (not decentish ones anyway), so you are only delaying the problem if you stay square-post.
Old Jan 3, 2011 | 02:36 PM
cozzy lee's Avatar
cozzy lee
thanks didnt know that mate,converting to roundpost asap by the looks of it...
Old Jan 3, 2011 | 02:43 PM
martysmartie's Avatar
martysmartie
It is still possible to get the original batteries, got one a while back from a local motor factor.
Martin
Old Jan 3, 2011 | 03:22 PM
www.carbatteryshop.co.uk
amongst others, Johnson Controls, the worlds largest car battery maker(owns several battery co's) still makes square, has to be said not all stock these though, ford been using round since at least 93, think BYD also do square.
Old Jan 4, 2011 | 09:16 PM
TMC225Y's Avatar
TMC225Y
I've bought batteries from ebay, should be type 085 on S1, but I normally fit 097, which is the type for older ford diesels, gives more cranking power, and has square posts. There is another hole in the mk3 battery tray to accomodate the larger 097 battery, as it was fitted to 1600D mk3s...
Old Jan 5, 2011 | 02:20 PM
Or a 095, this is what I use, VARTA BLUE, tbp.
Old Jan 5, 2011 | 05:53 PM
xrmalin's Avatar
xrmalin
When i needed a new battery for my 2i i was told the square ones were discontinued so i bought some adaptors that clamp to the terminal of the battery then have a seperate bolt to put the car's conections onto so you dont need to change your wireing around and they were only a quid for the pair
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
