water leak
Old Dec 24, 2010 | 07:26 PM
gemini50's Avatar
gemini50
Default water leak
hi
i have a 96 4x4 mondeo silver topped engine
i have a water leak, checked usual places floorpan etc, its been on pressure test but lost nothing, but loses when running, cannot see the leak, will it be the cylinder head ??
cheers
Old Dec 24, 2010 | 08:38 PM
jamie's's Avatar
jamie's
if its had a pressure test and didnt show anything up,
but loses water when running then it could be the head gasket blown between cylinder and water jacket,
get garage to do a sniff test on it,
its a small cylinder that goes over the rad cap,
filled with liquid, it changes colour if theres gases in it from the combustion chambers,
thats the way to tell for certain
Old Dec 24, 2010 | 08:53 PM
martysmartie's Avatar
martysmartie
Is it a V6? I know these blow HG's in an unusual place which a compression test etc does not show.
Martin
Old Dec 25, 2010 | 06:59 AM
gemini50's Avatar
gemini50
Martin
hi martin
no mate it a 2ltr silver top
cheers
michael
Old Dec 25, 2010 | 07:02 AM
gemini50's Avatar
gemini50
hi jamie
thanks for your quick reply, yep will do, i had and idea it was the gasket, there is an odd smell when i take the cap off to top up with coolant.
cheers
michael
Old Dec 25, 2010 | 05:13 PM
A sniff test is done BEFORE removing the rad cap, using a mot exhaust gas probe to immediately put into the air space in the tank, it does NOT come into contact with water/coolant.
The test kits that detect the gasses by colour change have nothing to do with sniffing.
HG on these is very easy, might as well do belt/tensioner at same time.
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
