Suitable starter motor for YB/T9
Old Dec 20, 2010 | 07:07 PM
Craigorypeck's Avatar
Craigorypeck
Default Suitable starter motor for YB/T9
Hi. Got the NA YB in and low and behold the starter wont fit!
Looks like the Cosworth sump is a bit wider than the pinto... Is there an alternative starter unit that will fit?
Some details- 9 hole cosworth flywheel turned down to pinto size with ring gear on, standard Capri bell housing.
Seems the starter only needs about 6mm inwards to fit the hole.
Before I get the angle grinder out can anyone help??!!
Thanks
Old Dec 20, 2010 | 07:38 PM
cabriolet's Avatar
cabriolet
which capri bellhousing some were inertia starters the cosworth starter is unique fella they charge loads for them ,two bolt or three bolt fixing threaded or non threaded gearbox
Old Dec 20, 2010 | 08:22 PM
Craigorypeck
The starter is a pre-engaged type. The bell housing has 3 bolt holes which are threaded. standard mk3 capri item AFAIA
I found a thread on this forum, post 13 & 14 give a few clues but I dunno what a Lucas M85 starter is and where to get one never mind a rover metro pinion.
https://passionford.com/forum/techni...-help-plz.html
Old Dec 21, 2010 | 07:05 PM
cabriolet's Avatar
cabriolet
that starter is standard pinto its too big fella the m78 starter is half the size and as i told u unique to the cossie [m85 is truck mahoosive size i think] right have had a think u need the m79 version of what u already have if u contact a re con company they will probably be able to help u fella ask for either of these 25400 or 25407 lucas oe numbers they must be m79 not any other manufactarers x ref to that number
Old Dec 21, 2010 | 09:18 PM
Craigorypeck
Thanks! I've been advised to go a few extra bucks and get a reduction geared more powerful unit.. it's smaller so will fit and will be able to cope with the upped compression.
Thanks again for the help!
Old Dec 21, 2010 | 09:51 PM
The_turbo_doc's Avatar
The_turbo_doc
Thumbs up wat
2wd starter same as 1.8 diesel escort pal
Old Dec 22, 2010 | 06:24 PM
Craigorypeck
Starter arrived today.. only ordered last night!! Anyways
The new starter only has 2 connections, old one had 3.
Can anyone tell me what goes where and whats left out, why?
Also is the pinion supposed to be on contact with the fly wheel at all times? Defo seems to be touching when held in place.
Obviously terminals A are the same.. Earth
Both have spade, old also has pole connector..
Thanks
Old Dec 22, 2010 | 08:08 PM
cabriolet's Avatar
cabriolet
earth u sure[ battery live i think ] lucar the same ,old starter has coldstart ie low amperage supply to coil
Old Dec 22, 2010 | 08:33 PM
Craigorypeck
I see! Thanks!
The flywheel has been machined wrong I think, ring gear is too close to the dust plate, doesn't let the pinion disengage.
Old Dec 23, 2010 | 12:24 AM
Craigorypeck
One last thing... Does the voltage from terminal C that feeds the coil on crank stop when engine is running???
Old Dec 23, 2010 | 05:47 PM
cabriolet's Avatar
cabriolet
term c is only live when u are cranking the engine over fella
Old Dec 23, 2010 | 06:02 PM
Craigorypeck
thanks for your help! Used a few washers to move the starter back to get pinion clearance. Bit of a bad design on the starter, one of the fixing holes is covered with the solenoid so a bolt wont go in... doctored the mount plate. jobs a goodin.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
marky_g
Sep 12, 2015 04:26 PM
