focus tdci no drive
Old Dec 8, 2010 | 02:44 PM
siby's Avatar
siby
Default focus tdci no drive
hi i have a focus tdci and just today i went to drive it and only got into second gear then when i went to put it into 3rd i lost all drive
its had a new clutch about 5000 miles ago
i put the car in gear let the clutch out and nothing happens
its as if i still have my foot on the clutch
any ideas what this could be would be greatly appreciated
thanks in advance
simon
Old Dec 8, 2010 | 02:47 PM
martysmartie's Avatar
martysmartie
Slave cylinder I suspect, does the pedal feel different?
Martin
Old Dec 8, 2010 | 03:03 PM
siby's Avatar
siby
the clutch pedel feels fine
i was under the asumption that if the slave cylinder had gone then the clutch would be disengaged
on mine the clutch seems to be engaged
Old Dec 8, 2010 | 03:26 PM
martysmartie
Sorry my mind was deep in thought in something else when I replied, can you select a gear without using the clutch? If slave cylinder the clutch would be not disengage I.E you wouldn't be able to select gear.
Martin
Old Dec 8, 2010 | 05:57 PM
siby's Avatar
siby
yes i can change gear
when the engine is running without my foot on the clutch i can select any gear including reverse and the car goes nowere
im a mehcanic and its baffeld me
Old Dec 8, 2010 | 06:12 PM
phil_focus's Avatar
phil_focus
check your brake/clutch fluid level, maybe its sprung a leak and soaked the clutch and its just slipping like mad!!!
was the dmf and slave cylinder replaced when the clutch was done??
Old Dec 8, 2010 | 08:17 PM
RichieST's Avatar
RichieST
Is the speedo going up and down? If so then you can rule out the clutch.
Old Dec 9, 2010 | 11:22 AM
siby's Avatar
siby
no the speedo doesnt move
Old Dec 9, 2010 | 12:08 PM
martysmartie
So we have established the clutch is disengaged, either that or unlikely is something in the gear box which is a miss, the DMF's are known to be problematic and so it may be something to do with this.
Martin
bookwyse's Avatar
bookwyse
Are you sute that it is actually going into gear and not just moving the gear stick!!!
The cables are prone to strectching and breaking.
Old Dec 9, 2010 | 12:10 PM
martysmartie
The cables are prone to stretching and breaking.
Very good point, check that before any of the above!
Martin
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
Sep 3, 2015 10:49 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
