Escort van heater smells like burning wood
Hi ive got a 2001 escort van, when i have the heaters on it smells like something is burning, smells like burning wood to me but could be something else, also the heater blowers are a little noisy sounds like the fan is catching somethingas its turning,
any ideas???? only just bought it ,
thanks in advance
thanks in advance
lift up your bonnet at the back under screen will be your heater blower fans encased in plasit cover
it sounds to me like you have a twig or some leafs catching the fans hense the smell and noise hope this helps
It's not a carbon filter but a pollen filter that filters the air before it gets ingested by the heater blower fan, a panel type affair much like a normal air filter, should be under the scuttle panel somewhere.
