erst fuel regulator (upgrade)
Old Nov 21, 2010 | 03:08 PM
owenglen's Avatar
owenglen
under the bonnet
Default erst fuel regulator (upgrade)
hi i have an erst running mfi i want to fit an after market ajustable fuel pressure regulator i have two pipes going to standed regulator
can i block the smalist off ????
or????
gis a clue whats best
thanks for your time in this matter
Old Nov 22, 2010 | 04:51 PM
owenglen's Avatar
owenglen
under the bonnet
has know one done this yet
Old Nov 22, 2010 | 04:58 PM
studabear's Avatar
studabear
leave it alone
Old Nov 22, 2010 | 05:02 PM
owenglen's Avatar
owenglen
under the bonnet
its not running only got 2 bar pressure ???????
Old Nov 22, 2010 | 05:08 PM
studabear's Avatar
studabear
afaik from reading in the rs turbo section the fuel pressure is set/ adjusted by the emfpr on the metering head,
Old Nov 22, 2010 | 05:17 PM
owenglen's Avatar
owenglen
under the bonnet
ok not sure what you just said i will look in to thiis emfpr
Old Nov 22, 2010 | 05:22 PM
chaffe's Avatar
chaffe
Turbocharging Technician
you need to look into how k-jet works, the fuel pressure is what determines the ammount of fuel going in, its not like an efi car with pulsewidth modulated injectors at a constant pressure accross the injector
Old Nov 22, 2010 | 05:23 PM
studabear's Avatar
studabear
electro magnetic fuel pressure regulator
Have you checked the fuel filter is free flowing, is the fuel pump good, with sufficent voltage and a good earth connection
Old Nov 22, 2010 | 05:25 PM
chaffe's Avatar
chaffe
is the correct answer
Old Nov 22, 2010 | 05:27 PM
studabear's Avatar
studabear
do I won a prize
Old Nov 22, 2010 | 05:29 PM
chaffe's Avatar
chaffe
do I won a prize
you win a free efi fpr
owenglen's Avatar
owenglen
under the bonnet
ar thanks i have checked all that and all seams ok so in the manual it shows a fuel pressure regulator and its just after the mfi surely that holds the pressure and backs it up to the mfi at the right pressure
Old Nov 22, 2010 | 05:36 PM
chaffe's Avatar
chaffe
there is an accumulator in the system too
Old Nov 22, 2010 | 05:37 PM
owenglen's Avatar
owenglen
under the bonnet
Adjustment screw on S2 Electro Magnetic Fuel Pressure Reg
is the adjustment the car to run rich or lean
am i right in saying this ??
Old Nov 22, 2010 | 05:39 PM
owenglen's Avatar
owenglen
under the bonnet
thats befor the fillter and i am getting fuel in there
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Sp3no
Sep 27, 2015 07:23 PM
