focus tdci won't start/run
Old 14-11-2010, 09:40 PM
expensivecheapcars
expensivecheapcars's Avatar
Default focus tdci won't start/run
i have a 2002 '02 plate focus tdci. it ran perfectly for 144k miles with no faults. one day it went to limp mode. fault codes were fuel rail pressure low and cylinder 4 above knock threshold. i got all 4 injectors and the fuel pump reconned. fitted new filter and clear supply line (to check for air ingress) and now it won't start. it will sort of tick-over for 2-3 seconds but dies. it piles out blue/white smoke while turning over. the correct fuel pressure is there and there are no fault codes showing and no warning lights. i put a new cam sensor and new glow plugs in recently. the engine has never lost power or economy and never used a drop of oil or water between services so i'm confident it's in good nick. any ideas?
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
massivewangers
30
01-10-2015 07:40 PM
jay030787
18-09-2015 04:38 PM
talon1
15-09-2015 10:27 AM
marky_g
12-09-2015 04:26 PM
Quick Reply: focus tdci won't start/run
