2.0 litre escort mk6?
hi people, im doing a conversion on an escort from 1.6 to 2litre. Silvertop , im aware that ill need to change sump, and water pump on the 2 litre for 1.6 items. is there anything else i have missed and can anyone give me a quick guide on it
cheers people
cheers people
i think its
sump
oil pickup pipe
water pump as they rotate the opposite way on the 2l (might be a case of swapping over all your anciliaries onto the 2l i cant remember)
1.6 or 1.8 flywheel and clutch.
then you'll need the modeo ecu, one of a couple of codes and a fairly simple rewire of the connector.
if you go onto www.feoc-uk.com i think theres a how to on there. if not theres a few people on there who have done this conversion a few times.
sump
oil pickup pipe
i think its
sump
oil pickup pipe
sump
oil pickup pipe
ok thanks mate, might go down the 130 spec 1.8 route now as ones come up at a decent price
seriously mate i'd go 2l!
135 bhp for the same money as buying cams and throttle body (if you look around) and more torque than the 1.8. then you;ve got the increased modability of the 2l as 4-2-1 manifold, decat, cat back and pannel filter should see upto 150 bhp.
to start with can i use my 1.6 flywheel, clutch and IB5 box? also can i retain std manifold and downpipe. been looking at a few 2litres now
yes you will have to use the 1.6 flywheel and clutch and you can keep your box.
you might have to use the 2l exhaust manifold. i hink you need the 2l inlet manifold aswell.
get yourself onto feoc, they will help you every step.
