Mondeo mk2 Heater problem
Old Nov 5, 2010 | 11:19 AM
Jessop's Avatar
Jessop
Default Mondeo mk2 Heater problem
Bit of a long shot, but I have a 1997 Mondeo 1.8 and the heater and air con only work on full blast. Don't have a clue but it is pretty annoying so any help is appreciated. Thanks.
Old Nov 5, 2010 | 11:52 AM
taycoss's Avatar
taycoss
Will most likely be heater resistor unit.
Old Nov 5, 2010 | 11:53 AM
It is almost defo the famous heater resistor pack burnt out, ford did a modified pack and loom to sort this which mostly did.
The reason why full speed only works is due to it being the full 12v where as the slower speeds are lower voltage supplied via a resistor.
The resistor pack is from memory ?, on the actual motor itself, so look up above where the passengers feet are in the front behind the glove box area.
Old Nov 5, 2010 | 11:58 AM
Jessop's Avatar
Jessop
Just googled it and yeah going to change that asap. Thanks for the replys guys!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Chopshop85
Sep 12, 2015 06:42 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
