Cossie exhaust manifold studs
Old Jan 27, 2005 | 11:32 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Cossie exhaust manifold studs
Need to buy a set for the 2wd, last time they set me back £80 for the 4x4 (stainless ones I think - apparently they don't rust ).
Are they REALLY that expensive Is there something about them or is it simply the ford markup ?
What spec are they ? I may have an alternative (and cheaper) supplier, but I need to know what I need before I talk to them.
Thanks in advance.
Greg
Old Jan 27, 2005 | 12:50 PM
Toe Knee's Avatar
Toe Knee
I know Brad got some titanuim jobbies alot cheaper and they were ok as far as i know!! Its making sure they dont come out from the vibrations thou
Old Jan 27, 2005 | 01:00 PM
frog's Avatar
frog
Brad ?
Old Jan 27, 2005 | 02:31 PM
Dave Henshall's Avatar
Dave Henshall
i ended up drillin gthem out form m6 to m8, re tapping them to m8x1.5pitch,
and fitting new studs with loads of copperslip on. you will have to drill 2 of the holes in teh manifold though as they are a very tight snug fit at m8, literally just pop a m9 drill through them. and i used new stainless nuts with again loads of copperslip on them. the intense heat must fook the facoty ones up as there will be no copperslip on them, only studlock, which is great for fit and forget, but then when u need to take it off to have the head skimmed etc, it s right pain as they either have alredy been stripped by someone else or they wont undo and strip
jessie_rs
62
Aug 6, 2019 09:27 PM
jamie956
21
Sep 16, 2015 06:24 PM
Thanasis
Sep 7, 2015 07:33 PM
hopper350
Sep 4, 2015 12:53 AM
