lights on dash perm on!
Old Oct 30, 2010 | 01:52 PM
Katwoman666's Avatar
Katwoman666
Angry lights on dash perm on!
Hi any one help ive got my brake light perm on and clock on dash showing lines and picture of engine light perm on dash,my machanic said its the ABS moduale and first sd £900 for part now saying £520 for part without labour? put machine on and showed up as fault code u0121 ABS seems a big diff when i querird the price with him can any one shed any light as to my problem and price range i should be looking at? Thanks for any help much appreciated
Old Oct 30, 2010 | 02:11 PM
phil_focus's Avatar
phil_focus
my code library gives me this for your code
"Lost Comm With Anti-Lock Brake System (ABS) Ctrl Mod"
could be a dodgy connector on the abs control module or more than likely a dead module which does happen from time to time.
i dont know how much they are new but they arent cheap. its only a very rare occurance that this happens from what i've read. i'd remove the module and not down any codes and then try breakers yards that offer warrenty with their parts. car transplants is near you. give them a ring, quote your reg and the codes on the module so they can match you an exact replacement, make sure they give you warrenty on it so if it doesnt work they will have to replace or refund you.
thats what i would do as hopefully should be a good deal cheaper and i'm a tight cunt
welcome to the forum too.
i recon we get one new person a day signing up with a problem, 99% of which have been seen before!
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
imnoteasy
Sep 7, 2015 09:26 PM
