hi chaps.just as i was driving home tonite in my 2wd cosworth,i pulled out of the junction and i heard a clunking noise from the rear passenger side,the noise is as vo something is catching on the wheel or propshaft as when i speed up the noise speeds up as vo its going round something.i checked underneath and everything looks fine,nothing catching or hitting,it sounds worse on over run but if i put the clutch in it goes abit quiter,also if i go round a sharp or tight right corner it clunks louder,
any thoughts or ideas,??
thanks guys
I'd have a close look at the joints on the driveshaft that side, and the other side, as noise often isn't coming from where it sounds like it is.
cheers lads,but found out that it was the anti role bar had come loose and the rear droplink bar had broke,its all sorted now.thankgod,lol
thankyou anyway
