Old Oct 30, 2010 | 02:11 PM
phil_focus's Avatar
phil_focus
my code library gives me this for your code
"Lost Comm With Anti-Lock Brake System (ABS) Ctrl Mod"
could be a dodgy connector on the abs control module or more than likely a dead module which does happen from time to time.
i dont know how much they are new but they arent cheap. its only a very rare occurance that this happens from what i've read. i'd remove the module and not down any codes and then try breakers yards that offer warrenty with their parts. car transplants is near you. give them a ring, quote your reg and the codes on the module so they can match you an exact replacement, make sure they give you warrenty on it so if it doesnt work they will have to replace or refund you.
thats what i would do as hopefully should be a good deal cheaper and i'm a tight cunt
welcome to the forum too.
i recon we get one new person a day signing up with a problem, 99% of which have been seen before!
