Omex rev limiter Escort zetec mk6
Old 26-10-2010, 05:26 PM
omightone
omightone's Avatar
Default Omex rev limiter Escort zetec mk6
Hi guys, i ordered a Omex rev limiter with launch control - Clubman twin coil.
But im kinda stuck on how to fit it. said its simple to install but im not really the type to mess with electricals. has anyone fitted one of these or can suggest how i fit it?
there is 2 blue wires a red and a black.
heres what it says in the instructions
http://www.omextechnology.co.uk/Revl...oads/RLCLC.PDF
(scroll to twin coil)
many thanks
steve.
Old 26-10-2010, 05:34 PM
Tank Mike
Tank Mike's Avatar
well your coil earths are pin 1 for cylinders 1&4 and pin 3 for cylinders 2&3 the coil possertive is pin 2
Old 26-10-2010, 05:36 PM
omightone
omightone's Avatar
cheers for that, do you have a diagram of one tho mate? to locate the pins?
Old 26-10-2010, 05:38 PM
Tank Mike
Tank Mike's Avatar
the pins are on the coil, theres a 3 wire plug on the side of the coil. Basicly, put the blue wires to both outside wires and the red one to the middle one.
Old 26-10-2010, 05:42 PM
omightone
omightone's Avatar
just to confirm, is this the plug going into it on the right? http://teambuttnaked.co.uk/coil2.jpg
cheers.
Old 26-10-2010, 05:43 PM
Tank Mike
Tank Mike's Avatar
yes
Old 26-10-2010, 05:44 PM
omightone
omightone's Avatar
Thanks very much, so the far left is coil 1 neg, and far right in coil 2 neg?
cheers for the help.
Vincereese
01-06-2023 09:14 AM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
Quick Reply: Omex rev limiter Escort zetec mk6
