Orion Gearbox/Engine Probs!?
Old Oct 17, 2010 | 07:35 AM
Rogeyboy's Avatar
Rogeyboy
Default Orion Gearbox/Engine Probs!?
Just replaced the engine in my mk2 orion and other than a few teething issues it now starts and runs well...
Altho out on the road and driving it, its fine under load but when you let off the throttle the whole car feels like im driving over speed bumps (making a bump bump bump noise in the car also) There is nothing rubbing and the wheels are all balance/not buckled.
I had to swing the gearbox around abit in the bay to get the engine into place, im wondering if maybe ive damaged something inside the box?
Any advice/suggestions welcome - Cheers!
Old Oct 17, 2010 | 02:00 PM
cabriolet's Avatar
cabriolet
gearbox mount fella would be my guess get a mate in the car to gently shunt the car backwards and forwards on the clutch u will see it all move
Old Oct 17, 2010 | 03:56 PM
Rogeyboy's Avatar
Rogeyboy
Mounts are vibratechs 2-3months old...
Think its more internal in the box!?
Old Oct 17, 2010 | 04:02 PM
kevboy6's Avatar
kevboy6
sounds like a drive shaft to me mate maybe
Old Oct 18, 2010 | 11:55 AM
Rogeyboy's Avatar
Rogeyboy
That could make sense as the shafts were pulled around and upset from there positions to get the engine in...
Maybe il try the shafts before i try the gbox, then!
Old Oct 18, 2010 | 07:34 PM
cosworth_wannabee's Avatar
cosworth_wannabee
when i swapped my lump in my old mk4, i left the box in and tilted it to get new lump in, when fitted i had exactly the same symtoms until the cv broke on the long shaft gearbox end. when tilted the shaft must have came out slightly and bent when going back in, it didnt last long tho, once the new shaft was fitted it was perfect. could be ur problem!!
Old Oct 18, 2010 | 08:32 PM
Rogeyboy's Avatar
Rogeyboy
Sounds about right m8 as that cv gaitor took a beating and the shaft popped 1/2 out on that side as i was refitting the engine - wouldve been easier to take the box out looking back, but retrospect is a lovely thing!
Anyway, so yours was like driving over a series of small speed bumps when off-throttle? If so thats sounds just like mine, so il give that a go before i change the box!
slammedorion
15
Nov 1, 2015 07:17 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
bassboy
Sep 10, 2015 08:54 PM
orionguy
Aug 6, 2015 07:36 AM
