Help needed no power to the injectors on a escort cosworth
it was running friday when i put it into the garage had to push it out today as it would not start checked for power at the injectors and no power everything is connected the right way round aswell
Are you sure its injector ? have you checked spark and fuel pump first ? (sorry always start at the begining )
fuel cut in boot?
spark at plug ?
pump priming.?
Have you changed anything latley ?
Fuel in car ?
Cheers Al
fuel cut in boot?
spark at plug ?
pump priming.?
Fuel in car ?
Cheers Al
right ok then,is there anything else it could be as you say it wouldnt spark or pump wouldnt prime otherwise
I presume when checking the power at the injectors you used an earth other than the injector earth wire, with igniton on?
If all four injectors have no power I should think you have a wiring problem.
Martin
Martin
DON'T check the earth at the injectors with a test light, this may damage the injector drivers in the ecu.
The fuel pump is controlled totally by ecu output so if it primes then ecu is getting power, if no live at the injectors then check the main power relay is outputting, this ends a live to the ecu and the same relay sends the live to the injectors, most likely a dodgy wire.
If you defo do not have power at injectors at the LIVE feed then as said it will be a wiring problem after the ECU relay as we have established the ECU is getting power and they share the same feed.
Martin
Martin
I personally would be looking at other possibles other than a whole injector loom gong down when it hasn't been touched and the car was runing fine. one assumes the car has an immobiliser other than standard key code system ? . do you know were the cut's are for it and have you tested them to rule it out? . have you tryed another key incase the chip isn't reading correctly ?
Cheers Al
Cheers Al
right ok then..i will check as you say the relay.and i have a set of noid light mate had no pulse or power. all the immoblizer is fine and alarm...its weird it was running fine now nothing
All i can suggest is that you check your earths are spotless and start checking the loom back to your ecu. Also may be worth getting hold of anther ECU to plug in and just rule it out ?
Cheers Al
Cheers Al
When I broke a lug off mine i had problems with sparking and injector pulsing!!! Like i say long shot if u just put it in a garage before fault but worth checking as it took me a while before I thought of checking the lugs!!!
