mot question..
Old Oct 7, 2010 | 05:32 PM
s1cab's Avatar
s1cab
Default mot question..
what does a car need to pass an mot. im building a track car but want to complete the light circuit in case i want to take on the road in the future. It's all solid and all new bushes/suspension so its fine there. do you need a handbrake light on the dash to show that the handbrake is on ? anything i've missed?
thanks in advance
Old Oct 7, 2010 | 05:54 PM
steves24V's's Avatar
steves24V's
you need tell tail lights for indicators and hazards, rear fog tell tail, high beam tell tail is only a advisory not a fall so not needed but i'd have one, if the car has abs needs a light for that but thats about it iirc hand brake light is not needed.
Old Oct 7, 2010 | 06:00 PM
cossie604's Avatar
cossie604
Im a tester so I could answer your question, but your question's answer could go on for a bit
Easiest way is for you to look at the inspection manual your self.....try vosa's own site or www.motuk.co.uk
Old Oct 7, 2010 | 06:01 PM
s1cab's Avatar
s1cab
thanks for that info
Old Oct 7, 2010 | 06:05 PM
s1cab's Avatar
s1cab
thats some manual .. thanks
Old Oct 7, 2010 | 07:21 PM
I'm not sure about the handbrake light, but you don't need any actual lights on the car so can't see that you'd need a rear fog warning light.
Just get a daylight mot, easiest way if that suits, ie you don't need to drive in the dark.
Old Oct 7, 2010 | 07:42 PM
s1cab's Avatar
s1cab
could be a good option !
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
