Gartrac c20let rwd escort
Old Oct 6, 2010 | 10:09 PM
cozi500's Avatar
cozi500
Default Gartrac c20let rwd escort
Im after some advice, some of you may have been following my G3 rebuild, most things are now done, the problem i have is the fuel tank is in the boot, with AN8 male fittings, do i need a swirl pot, what pump should i use, and what size pipe shoud i use, hopefully someone out ther can advise me of a good realable set up . im runnig 1000cc injectors, basically im after a diagram of the full set up. tank, pump, filter, pipes, where they should go, please male me .
Old Oct 6, 2010 | 10:11 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
for what power?
Old Oct 7, 2010 | 05:37 AM
cozi500's Avatar
cozi500
It should push around 400bhp with all the mods done.
Old Oct 7, 2010 | 07:21 AM
Chip's Avatar
Chip
a single 044 pump would be fine then if you are only going to need to flow 400bhp
Old Oct 7, 2010 | 07:38 PM
cozi500's Avatar
cozi500
Will i need a external swirl pot. ive got an alloy tank in the boot with AN8 male fittings, will this pipe straight up to the 044 pump.
Old Oct 7, 2010 | 07:47 PM
graham c's Avatar
graham c
i needed a swirl pot in mine but sixty quid for a good one with an8 fittings ebay
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
28
Sep 8, 2015 07:10 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
