Sierra 2WD bad vibration ...
Old Oct 4, 2010 | 02:44 PM
ThomasV's Avatar
ThomasV
Default Sierra 2WD bad vibration ...
My 2wd vibrates quite bad and it is most noticable at a certain RPM.
It occurs both in gear and in neutral as well.
If it's a DIFF or Gearbox problem, would it still be doing it when rev'ing in neutral ? ...
I'm suspecting a gearbox mount, but haven't had time to check it yet and i'm guessing that some of you guys have experienced something similar.
Thomas
Old Oct 4, 2010 | 06:29 PM
Alvyn's Avatar
Alvyn
more than likely to be your exhaust down pipe is catching the floor or bulk head due to worn engine mounts or their loose!
Old Oct 4, 2010 | 06:49 PM
boy-racer-1's Avatar
boy-racer-1
ive got the same problem atm and im 90% sure mines gearbox mount only way i can guess it really is when i push down on the gearstick you can feel/hear the change in vibration, but it could still be the engine mounts, new ones from ford are £90 each round here hence why i still havent done mine lol, id say its more then likely engine or gearbox mount bushes though
Old Oct 4, 2010 | 07:50 PM
ThomasV's Avatar
ThomasV
The engine mounts where replaced 3-4 months ago with brand new OEM mounts .... So gearbox mount is probably the fault. I will check out the downpipe as well ...
Thanks for all inputs.
BR
Thomas
Old Oct 5, 2010 | 05:17 AM
Alvyn's Avatar
Alvyn
have you got the spacers fitted that are in between the mounting bracket and the floor??
Old Oct 12, 2010 | 03:23 PM
boy-racer-1
nope i didnt know there was spacers?
changed the gearbox mount bush on mine today though and drives fine now with no vibration atall
robbo9006
11
Sep 1, 2015 02:10 PM
FlashRS
13
Aug 31, 2015 06:02 PM
andyrs1600i
Aug 30, 2015 07:21 PM
Vincereese
Aug 15, 2015 06:24 PM
Old ford
Jul 31, 2015 06:50 AM
