T34 Turbo - .63 cool / .63 hot
Old Oct 3, 2010 | 06:03 PM
kaisersolsay's Avatar
kaisersolsay
Default T34 Turbo - .63 cool / .63 hot
Anyone used this config for the T34? If so how laggy is it? I have this setup for my Mk1 Cortina Cossie 4x4 but not sure if she will be too laggy.
Old Oct 3, 2010 | 06:17 PM
LHD220Turbo's Avatar
LHD220Turbo
laggy compared to what?
t34.63 will make 400hp on the right spec - its an awesome road car set up.
t34.63, ab07 inlet, siemens 55lbs injectors, and a decent chip such as MSD, 2.2bar of boost would see 400hp. be careful of the standard 4x4 gearbox thou, anything beyond 400/400 is a lottery
Old Oct 3, 2010 | 06:27 PM
J1mbo's Avatar
J1mbo
B1mbo
On a STD engine to push 400 out of a t34 is asking a little too much and they don't like holding 2.2 bar at high revs, I spike of 2.2 is good but they are Time bombs at that boost iirc mike rain bird done a few t34's pushing over 400 bhp
The .48 is better for a road car IMHO though loose 20 or so hp for more response
Old Oct 3, 2010 | 06:28 PM
kaisersolsay
What about the bottom end? Its been lightened and balanced but standard pistons and con rod bolts.
I'm after reliability as the car is more of a street sleeper than track / 1/4 mile dragster.
Old Oct 3, 2010 | 06:31 PM
J1mbo's Avatar
J1mbo
B1mbo
STD engine bottom end is fine but a uprated head gasket is advisable something like a 0611/grp a gasket
Old Oct 3, 2010 | 06:41 PM
kaisersolsay
Yip got a grp A on her.
Set up is;
0.75 overbore (lighten & balanced cranks, rods, flyweel)
T34 .63 / .63
3 bar MAP
Greens
Pro Alloy 50mm RS500 I/cooler
MSD chip to match above.
What do you think she will put out? Was hoping 350bhp.
Old Oct 3, 2010 | 06:44 PM
LHD220Turbo
your limiting factor is greens, it will piss 350 if the greens dont max out; you dont want to go over 80% duty ideally.
Old Oct 3, 2010 | 06:46 PM
kaisersolsay
so blacks are the key then?
Old Oct 3, 2010 | 06:49 PM
LHD220Turbo
if you want to get the best of the spec then yes; but you'll need a new chip.
J1mbo's Avatar
J1mbo
B1mbo
Light blues/ 400's
We do a lot of these conversions around 380 ish bhp as they go fantastic
Old Oct 3, 2010 | 07:07 PM
kaisersolsay
May stick with the greens for now as the chip I have matches the kit. You know what like......I'll probably upgrade to light blues and remap after a few weeks!
Old Oct 3, 2010 | 07:16 PM
105epwr's Avatar
105epwr
Originally Posted by J1mbo
Light blues/ 400's
dont they just-mine still scares me!!
Old Oct 3, 2010 | 07:48 PM
Could always go greys, or as said blues.
T34.48 make a awsome road car around 380 bhp, same as CR turbos used to run in his sapphy, T3/34 makes pick up a little earlier still.
Old Oct 3, 2010 | 08:05 PM
J1mbo's Avatar
J1mbo
B1mbo
It really is just great its as punchy as the greens but they just pull hard to the limiter !
Lol! Think this is the conversion for me or very similar
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
Danielbetty
Aug 23, 2015 12:52 PM
kosienutter
31
Aug 22, 2015 09:55 AM
