2wd Sierra Cosworth sump ?
hi .. just want to ask optionions about if I need to modd. the sump as I have started to do some trackdays and was thinking about oilstarvation ?
Just baffle the existing one, personally I didn't bother with big wing just baffled in the sides then a 1/2" hole in each baffle plate, but I run extra 1/2 litre fill anyway.
Sadly no, I didn't take a piccie(just checked), but dead easy to do, if you imagine the square "hole" in the metal plate just cut and weld a flat bit of metal some that they "box" in the sump, just the box has no lid as the pump pick up goes through there,
Effectively just a wall of 4 sides that extend from the sump floor to the metal plate, then about 1 1/2" down from the metal plate on each wall drill/punch a 1/2" hole, leave a 5mm gap between the base of each plate and the sump base.
The sump takes 3.5 Litres to fill the sump to the level of the "slant" above the plate.
I can do a rough piccie if you want but can't post happy to email if wanted, it will be rough as picasso has nothing to fear my my drawing ability, well lack of!!
09-10-2015 07:38 PM
rog
04-09-2015 12:10 PM
155lee
14-08-2015 11:21 AM
adam151082
11-08-2015 04:50 PM
