speedo cable
Old Mar 23, 2004 | 07:04 PM
Moondust_crust's Avatar
Moondust_crust
Default speedo cable
my speedo has been bobbing up and down all week and today finally gave up the ghost , got a new one just wondered how hard they are to fit? cheers in advance , mark.
Old Mar 25, 2004 | 06:07 PM
B11GNS's Avatar
B11GNS
Easy m8,
remove upper and lower s/wheel shrouds
remove black part of dash(part that goes round the clocks
remove clocks
unclip cable from behind clocks
pull out from engine bay(2 grommets)
from under
remove circlip from g/box and pull free
remove from car
fitting is the reverse
should take 15 mins
HTH
Old Mar 27, 2004 | 10:52 PM
It could also be the plastic gear in the gearbox that worn, mine bobbed up and down for ages then gave up the ghost. Fitted a new cable (Not that easy unless you can jack the car very high, its right in the middle of the car) and it still bobs around... Apparatly the gear is £3 but you need to drop the box a little to fit it. Still dont think its that big a job though. To much for me however
Old Mar 28, 2004 | 09:26 AM
Moondust_crust
turns out it was the speedo cable as it had broken in 3 places
cheers for the info B11GNS u have no idea how helpfull it was , the circlip was a bit of a bitch to get out but got it out in the end. cheers lads
Old Mar 28, 2004 | 09:03 PM
Nice one!! a job well done
Old Mar 29, 2004 | 04:51 AM
B11GNS's Avatar
B11GNS
No probs.
Old Jun 18, 2004 | 05:23 PM
stew205's Avatar
stew205
Has anyone got a pic of this circlip???
I'm just fitting a new cable (as old one was broke at gearbox end). I am obviosly missing this circlip but not sure if I am missing any other parts.
I will post a pic up to show what I mean.
Old Jun 18, 2004 | 05:40 PM
stew205's Avatar
stew205
Or is that the clip with the bolt holding it in????
Old Jun 18, 2004 | 07:25 PM
MadMac's Avatar
MadMac
Just hope it aint the ring gear on the gearbox
Old Jun 18, 2004 | 11:02 PM
B11GNS's Avatar
B11GNS
The bolts got nothing to do with the circlip, the circlip is inside a groove on the inside of the opening where the cable (in your case the broken off bit which is sticking out) comes out, look inside the opening and you will see it.
Old Jun 19, 2004 | 10:44 AM
stew205's Avatar
stew205
Thanks steve.
I was looking at it from the wrong perspective, I didn't know that bit sticking out was part of the old cable (I thought it was part of the gearbox!)
Got the circlip off and have fitted the new cable so hopefully everything should be fine, cann't test it till I sort another niggle out first.
Thanks
Stew
muz
Sep 30, 2015 08:29 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
