3 door and saph rear turrets
Is there a difference between the two?! Got a strut brace off someone I work with which gfs ex had left behind but didn't know what it was for, tried it on mine but can't get it to fit my sapphire so wondered if there is a difference between the two invade it was meant for a 3 door.
Said it was deff off a cossie thou!!
Tony
Tony
Easiest way is just buy some 3/4" square drill a hole in each end to suit and use slightly longer eye bolts on the top mounts, being just on one side will work on the road no probes, ideally these want bracing from each turret to the centre floor area though, but can be made as a complete "bolt" job so no welding involved if you wanted.
That would work well, if you put a left hand one in one end could just turn to adjust then without having to take off, if you want a left hand thread doing just pm me, and I'll knock up a slug with a l/h thread in it for you, then just weld on bar.
jessie_rs
11
03-06-2019 04:57 PM
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
mrice0107
21-08-2015 07:55 PM
