Help!! Fiesta rs turbo breather system
Hi all, I'm new to the site and i'm in need of help.
I've a problem with my car. I think i've blown my turbo as its smoking white smoke. I've done a compression check and the head gasket/piston rings are fine. I believe the oil seals have gone in the turbo and i don't want to replace it until i know why it blew as it was a new turbo.
I'm confident its the way the breather system is set up. My car is running a ZVH setup with a T3 turbo conversion and i seem to have a load of blocked off breather pipes. I've checked all the pipes and they are clear of obstructions.
Here's the way my breather oil breather is currently setup.
- One pipe with a one way return valve that goes to the cylinder head.
- I've another that goes to the rocker cover
- The other side of the rocker cover has a crank case breather kit.
- Another pipe off the oil breather is currently blanked off
- The final pipe connects the sump to the oil breather.
![](http://i236.photobucket.com/albums/ff187/PBRADY/12072010108-MOD.jpg)
paceo
03-02-2016 10:31 AM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
