clunk when letting off accelerator
Old Jul 24, 2010 | 12:58 PM
alphaboy's Avatar
alphaboy
Angry clunk when letting off accelerator
my mk2 fiesta has a signnificant clunk when letting off the accelerator at first it was only after hard acceleration but now it is all the time. any ideas ???????????
cheers
Old Jul 24, 2010 | 01:16 PM
foreverford255's Avatar
foreverford255
engine mount possibly
Old Jul 24, 2010 | 04:28 PM
DanJWRC's Avatar
DanJWRC
WTD:S1botom end&bodykit
Yep as above sounds like a mount
Old Jul 24, 2010 | 05:21 PM
alphaboy's Avatar
alphaboy
thanks for the replys. i basicaly know fuck all mechanicaly but just ad a look underneath and thefront tie bar to chassis bushes are virtualy non existent i think. could this be the cause???? also i thought the bushes were rubber but they are like an off white colour foam that is crumbling is this normal
Old Jul 24, 2010 | 05:27 PM
DanJWRC's Avatar
DanJWRC
Can you get a picture or 2 mate... does it knock going over bumps?
Old Jul 24, 2010 | 05:30 PM
mercgrey's Avatar
mercgrey
id say gearbox mount
Old Jul 24, 2010 | 06:17 PM
foreverford255
them tie bar bushes wont help but if you open the bonnet put the handbrake on tight then slowly try and pull away you will see the engine lift significantly if a mount has gone
Old Jul 24, 2010 | 07:38 PM
alphaboy's Avatar
alphaboy
just tried that and there was some movement maybe an inch or so it was the back of the engine and it dropped. and no it is fine over bumps just when letting off accelerator. cheers
Old Jul 25, 2010 | 07:53 AM
mercgrey's Avatar
mercgrey
i had them go on my old fiesta and it ate through the waterpipe at the front cuz the alternator touched it and took chunks out the back of the filter housing lol
i usually just rock the engine when cold and then the gearbox too and you will see any excesive movement mate!
Old Jul 25, 2010 | 09:17 AM
foreverford255
i would change the gearbox cradle mounts mate ,most likley cause
Old Aug 6, 2010 | 09:16 AM
kitted_escort's Avatar
kitted_escort
if 1 of ur engine mounts have gone, tryin looking at ur others, ive had 2 change two of mine in my escort when 1 spaned
Old Aug 6, 2010 | 04:56 PM
JamesyRS's Avatar
JamesyRS
front tie bars will be the problem, brothers have had many mk2 fezs everyone same thing, very big clunk on acceleration and letting off exact same as theirs take about 15 mins to change, get them on ebay for a few quid aswell, unless engine movement very excessive I will gurantee those are the problem!
tankybaby66
Feb 6, 2016 02:24 PM
Sep 28, 2015 10:05 AM
