Help! Very strange noise.
Old Jul 17, 2010 | 11:41 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Default Help! Very strange noise.
Hi all, I have a very strange noise coming from my car when the clutch is up, and it's in neutral. It's a kind of knocking, but used to only do it when cold, now it does it most of the time (only when stopped and in neutral with no pressure on clutch). Just got in, and its now making a kind of whiring noise aswell, that kind of 'speeds up' dependent on the amound of pressure on the clutch. Car had a low milage engine and re-con gearbox fitted about 1000miles ago, so it seems strange that it's doing this. Car is a 2001 (mk5) fiesta zetec S. Any help would be appreciated!
Sam.
Old Jul 18, 2010 | 12:17 AM
botters's Avatar
botters
competant bodger
these are prone for clutch release bearings being noisy but that wouldnt make a knocking noise tho just a dry bearing noise
Old Jul 18, 2010 | 12:28 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
hmm, the whiring could be bearing, would the noise change dependent on the preesure on the clutch? I only noticed that noise tonight though, the other noise has been there for a little while. Cheers for your input
Old Jul 18, 2010 | 09:41 AM
Yes noise could change with the pressure on the clutch pedal, a lot of fords have a noisy bearing, but it defo won't cause knocking.
Old Jul 18, 2010 | 11:41 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
I know my engine mounts are a bit worn, could this have something to do with it? It's not a massive knock, like bottom end or something, just a slight clunking.
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
