cosworth cam belt problem
Old Jul 17, 2010 | 10:53 PM
intruder dai's Avatar
intruder dai
Default cosworth cam belt problem
put new belt and tensioner on tday but noticed belt not strait goin from left cam to tensioner afraid to start it lol is this normal or is sumut missin from behind the tensioner
Old Jul 17, 2010 | 10:56 PM
155lee's Avatar
155lee
is the tensioner on the right way round?there is a front and back to them.
Old Jul 17, 2010 | 11:05 PM
intruder dai
yes think so bigger nut to turn then the lok nut i ad the cam pulleys off to change seals but they seem to be rite if u look from the top the belt goes in towards the engine from the bottom of left pulley into the tensioner
Old Jul 18, 2010 | 12:33 AM
jon@work's Avatar
jon@work
are you sure you put the cam pulleys back on the right way round ?
Old Jul 18, 2010 | 09:27 AM
LHD220Turbo's Avatar
LHD220Turbo
post up a pic, i suspect you've put something on back to front
Old Jul 18, 2010 | 09:38 AM
Loosen the tensioner and rotate the opposite way, this will have the effect of raising the belt run between the cam pulley and the tensioner, which should be parrallel with the belt run between cam pullies, some say if not it can run on the stat housing, think from memory you turn the tensioner counter clockwise to raise belt run up.
Would still be perfectly ok as yours is though, I've yet to see a run like that causing problems.
Old Jul 18, 2010 | 01:02 PM
jon@work's Avatar
jon@work
no - clockwise
Old Jul 18, 2010 | 01:09 PM
intruder dai
thanks for your replys put pulleys on the way they come off but if u turn them round they seem to line up so which is correct way thers a big nut shape on one side the other is round is the nut shape suposed to be on the inside thanks all.
Old Jul 18, 2010 | 01:23 PM
jon@work's Avatar
jon@work
nut side closest to head
Old Jul 18, 2010 | 01:27 PM
intruder dai
thanks for that they were on the rong way sorted thanks all.
RUBY123
Oct 22, 2023 12:04 PM
CLIVE
Oct 2, 2015 12:58 PM
cos elle
Sep 1, 2015 06:48 PM
Aug 14, 2015 07:29 AM
taylora1409
Aug 12, 2015 12:06 PM
