Mk4 Escort Door removal
Old Jan 19, 2005 | 12:34 PM
petet's Avatar
petet
Default Mk4 Escort Door removal
I will be swapping my rusty doors at the weekend for some nice shiny delocked ones.
I need to know how you guys would go about removing the door hinge pins, I have seen a door hinge pin removal tool for sale on some websites but it states its for hollow hinge pins, would this work?
I know i can unbolt the whole hinge from the car, but looking at it it looks like this is easier said than done with the dash bolted in place!
Cheers in advance
Pete
Old Jan 19, 2005 | 12:42 PM
magic randy's Avatar
magic randy
undo the bolts, much much easier than ya think
Old Jan 19, 2005 | 12:46 PM
petet's Avatar
petet
Sorry, Just thought as well, the doors i'm putting on have only got the pin, the rest of the hinge is missing! so I need to remove the hinge pin on my old ones!
Any help anyone can offer?
Old Jan 19, 2005 | 06:19 PM
petet's Avatar
petet
anyone?!
Old Jan 19, 2005 | 08:37 PM
tonyturbo's Avatar
tonyturbo
a fooking nightmare what ever way you do it.
Old Jan 20, 2005 | 04:33 PM
petet's Avatar
petet
Am I best using a drill bit or something similar and a big fook off hammer to knock the pins out then?
Is this how everyone else does it - or is there a tool I should be buying?
Old Jan 20, 2005 | 06:25 PM
magic randy
the drill will shatter as its hardened use a punch instead
Old Jan 20, 2005 | 07:15 PM
petet's Avatar
petet
cheers mate
Old Mar 7, 2024 | 08:33 AM
Aldan0502's Avatar
Aldan0502
after I pull the locking c clips I just use a hammer and punch, the reason I ask as the head looks kind of like a Torxbit or spline key headcap (they're still covered in paint) that need removing first, but you say that,, that is just the head(stopper) of the pins, and that there is nothing I need to un-BOLT,to remove the pins, normally I would un-BOLT the four hinge bolts but the door I bought to 're place my rotten ones, one was cut on the hinges,,,, so it's just remove c clip and just hammer the pins with force and a punch and possibly a bit of heat may help worse case,scenario?
Old Mar 7, 2024 | 09:24 AM
GVK.'s Avatar
GVK.
fesyturbo
Jul 30, 2012 02:40 AM
no1birdman
Ford XR Range
Jan 11, 2012 08:33 PM
auldy
Jul 29, 2011 10:26 AM
oriont
Jan 20, 2008 09:53 PM
Windle
14
May 3, 2007 05:34 PM
